display measurement of x y data(indicator) inside waveform graph
Good Day
Can I know on how to display reading or measurement of x y data(indicator)  inside waveform graph?
attached also my study pupose vi
Best Regards
Tarmimi
Message 1 of 8
(3,650 Views)
I'm not clear about what you want. Do you want to annotate specific points? Query points with a cursor? Show summary data?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(3,626 Views)
good day mike
Thank for your fast reply..
sorry for the misunderstanding....i don't know the correct term...
i want the measurement  data to  display on the graph( example in attachment below Vpeak2 T1 Front Tail 2) ...
Best Regards
Tarmimi
Message 3 of 8
(3,610 Views)
I could not run your VI becasue I'm missing the VI double exponential waveform, but I got the idea. Checkout the waveform graphs annotation list property:
By writing the Position value to be the desired Peak location, label offset so that it would appear below/above/etc., and name, you can add all annotations programmatically.
Is this what you mean?
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
Message 4 of 8
(3,606 Views)
Hi Danielle
Thank for your help
sorry also  forget to attached the subvi exponential waveform
"By writing the Position value to be the desired Peak location, label offset so that it would appear below/above/etc., and name, you can add all annotations programmatically"
I'm very sorry I could not understand the sentence very well... can you gave me an example in VI
attached also my subvi..
Best Regards
Ahmad Tarmimi
Message 5 of 8
(3,593 Views)
Accepted by ahmadtarmimikassim
Here is an example. You can also Refer to the Graph Annotations VI in the labview\examples\Controls and Indicators\Graphs and Charts\Graphs - General directory for an example of using the Annotation List property (or search for "annotations" in the example finder).
Good luck!
Danielle
― Terry Pratchett
Message 6 of 8
(3,589 Views)
Hi Danielle
thank for your strong support
Best regards
Ahmad Tarmimi
Message 7 of 8
(3,573 Views)
You're welcome and good luck!
Danielle
― Terry Pratchett
Message 8 of 8
(3,568 Views)
