combo box auto-updating
Hi, all
I founded that LV don't update Combo-Box constant that created from custom type control "Combo-Box".
Assume we have some custom control "Combo-Box" that have 3 strings. If i create now in diagram constant from this control and add new item in Type Control, the constant is not updated. But if i change constant to control, is updated.
If someone have any idea how to update all constants that linked to Type Control?
Message 1 of 20
(4,808 Views)
Saving the combobox as a strict typedef will fix this I think, although will limit you if you want the comboboxes to look different in each instance that it is used.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 20
(4,795 Views)
Saving as a strict type def does not work, it looks like a LV bug.
Message 3 of 20
(4,790 Views)
Interesting, If you place an indicator or control linked to this combo-box strict typedef, it works but not with a constant on the diagram.  Now if you convert the constant to an indicator and then back to a combo-box, it is updated? Guess this is a bug unless there is some reason for not implementing this?  I have used typedef enums many times and this is not a problem, I don't understand the difference. Sorry
Paul
Paul Falkenstein
Message 4 of 20
(4,786 Views)
I am using LV7.0 and WinXP incase this has been fixed in 7.1 or 7.1.1
Paul Falkenstein
Message 5 of 20
(4,782 Views)
I was able to reproduce this in 7.1.1.  I will report it to our R&D department.  I noticed the exact same behavior...if you flip to a control and then back to a constant it updates.
-Brett Burger
Applications Engineer
Message 6 of 20
(4,765 Views)
This issue is still present in LabVIEW 8.20.
How peculiar. I would expect a type definition would work with constants as well. However, combo box seems to be an exception. Is this a feature or a bug?
Message 7 of 20
(4,559 Views)
tikus,
I'm havig a hard time reproducing this in 8.20. My procedure is as follows:
1. Open a blank vi.
2. Put down a combo box
3. Right click on the combo box and select Advanced>>Customize.
4. Change to a strict Type Def.
5. Add three items (a, b, c).
6. Save the type def.
7. Close and when prompted replace the original with your new type def.
8. Save the vi that contains the new type def.
9. Reopen the type def by right clicking the combo box and selecting "open type def".
10. Add another item "j".
11. Close and save the type def.
What happens when you follow this procedure?
Chris C
Message 8 of 20
(4,539 Views)
Hi, thanks for trying to replicate the problem.
The problem only affects combo-box constants on the block diagram, not controls on the front panel. In your case, try converting the control into a constant on the block diagram, and repeat adding items or modify the type def. You will find that the constant is not updated with the new type def.
To work around this bug, I use enums instead of combo-box. When I want to extract the string value of the enum, I use the 'Format into String' function. It works nicely.
Message 9 of 20
(4,532 Views)
tikus,
Ah! I was able to reproduce the problem with the following steps:
1. Open a blank vi.
8. Change the combo box type def to a constant.
10. Add items (1, 2, 3).
11. Save and close the type def. Note that the constant was NOT updated.
12. Change the constant to a control. Note that the control now reflects the changes to the type def.
This was reported to R&D (439C3E3U) for futher investigation. Thanks for bringing this to our attention again!
Chris_C
Message 10 of 20
(4,515 Views)
