changing xy graph scale using combo box selection
I have a xy graph with x scale set to 10k and y scale set to 6 by default.
I have a combo box which i use to select what the graph will display. For example in combo box i have 3 choices, A, B, C.
If i select A, xy scale is set to 10k and 6. If i select B, xy scale is set to 2.5k and 8, if i select C, xy scale is set to 4k and 10 respectively. Is there some functions that i can use to do this?
Thanks.
(4,132 Views)
Accepted by BPBP
Like this (attached)?
Of course, if the data actually follows these mins and maxes, you could just turn on auto scaling and it would do it automatically
Tim Elsey
Certified LabVIEW Architect
(4,121 Views)
Thanks.
(4,107 Views)
Can you mark tim's message as the solution instead of yours?
You can easily unmark it by clicking the options and
19481i964A24A1B6DD4E7D
(4,040 Views)
done!
didnt realised i marked the wrong post as the solution.
(4,018 Views)
Thanks.Smiley Happy
(4,014 Views)
