12-11-2008 09:00 AM
OK I think I see your problem now. You are working on computers. One with LV 7.1, and one with a newer version 8.xx. On the computer running LV 8.xx you have a additional toolkit installed. This toolkit is called NI LabVIEW Report Generation Toolkit for Microsoft Office. I do not know if this toolkit is available in labview 7.1. But this is the source of your problem. Then install a toolkit in LV you install it to a labview version. If you are running two LV versions and have installed the toolkit to LV 8.xx. Then LV 7.1 will not know about this toolkit
12-11-2008 07:50 PM
t06afre,
i hv install the toolkit when i use the labVIEW7.1 PC. and can not find the vis in Ravens Fan's pic.
Ravens Fan,
there no excel or word in my lv pc now. you means i should install office first? then i can try it later.
12-11-2008 08:22 PM
i installed office just now,and reinstall the report toolkit ,but the office vis are still missing....
12-11-2008 09:29 PM
thank you for answering my questions.
i have already solve the problem.
it seems that the report toolkit must be installed in the same directory as labview...
below is my directory:
old----------D:\Program Files\Report Generation\
new--------C:\Program Files\National Instruments\LabVIEW 7.1\
after reinstall in the new directory, i finally found the excel vis in my function palette(see the attached file.)
then i try to uninstall the office and found the excel funcion doesnt work (althouth it can be found in the palette).
so office program is also need to be installed.
