08-21-2006 11:50 PM - edited 08-21-2006 11:50 PM
Message Edited by Nick_F on 08-22-2006 12:03 AM
08-22-2006 12:13 AM
07-08-2009 12:42 PM
I was wondering where you attached the default directory to? Base path?
Lawrence
07-09-2009 09:03 AM
07-26-2011 02:08 AM
How exactly do you do this? I am getting the same error message when trying to open a file in my default case, writing to it in the next two cases, and then closing it in the last case. (And I'm having problems closing my AWG, but that's fine).
07-26-2011 03:28 AM
If you place the attached as a sub-vi, it will provide the folder that the calling vi is stored in. This will work in both the development environment and in an exe.
Is that what you need?
07-26-2011 06:13 AM
Hehe 🙂 It didn't quite solve my problem, but it solved another problem I've had! I'm not sure how I should have used it to extract the absolute file path and use it further.
I solved the problem with my current structure by using local variables instead of global. I hope that wasn't a bad fix?
07-26-2011 06:35 AM
Try putting changing the case statement so that the case for 'Run Time System' only has one strip path, and the default case just wires the path straight through without changing it. This should give you the path of the file rather than the folder it is in.
Apologies if this still isn't what you're after... I'm guessing a bit as I can't open your code as I'm on an old version of LabVIEW (8.5)
Ian
07-26-2011 08:44 AM - edited 07-26-2011 08:47 AM
Here's the simplest way to return the folder directory path of the current VI; just open the snippet up in LabVIEW to view the code.
07-26-2011 08:57 AM
This would seem relevant at this point, in case anyone gets any surprises:
Why Does My Executable Not Work When Using the Current VI's Path Constant?
