X Control Distribution (Bug?)
Hi Jim
Can you ammend CAR #236395 with this?
AQ said: "Just as important: The Data.ctl and State.ctl of that XControl should *not* show up in the auto built palette"
Cheers
-JG
Certified LabVIEW Architect * LabVIEW Champion
Message 31 of 41
(2,460 Views)
Hell JG,
I was able to reproduce the issue here. I will have to talk with R&D about this one but at this point, I thinking it might be a bug. As soon as I have more information about this, I will post it here.
As for the CAR I will add this in there tomorrow so we should be good there.
Finally, I looked at VI Package Manager and this is pretty cool. I'll have to spend some time looking into it. Also the VIs your VIPM files added are really cool.
Jim St
RF Product Support Engineer
Message 32 of 41
(2,452 Views)
That all sounds like great news Jim!
I am also glad you like VIPM, as I am sure you have seen now that it is very easy to use and a very powerful way to share code (and avoid the issues I had sending you my code in another form). It would be nice if this was a standard for R&D (hmmm that gives me an Idea)
I look forward to (hopefully) creating a CAR out of the palette issue!!
Cheers again
-JG
Message 33 of 41
(2,443 Views)
Hello JG,
One of my colleagues found a bug that states "Any VI's belonging to a class that in turn belongs to an lvlib will display a red x glyph when placed on a palette." I am pretty sure this is your case so I added your information to it. The workaround for this is take the class out of the lvlib. This isn't much of a workaround but I thought I would tell you about it.
I appreciate all the time you put into it. This will definitely help us get these things fixed in LabVIEW.
Jim St
Message 34 of 41
(2,427 Views)
Thanks Jim
Yes.. the workaround will not help due to maintaining namespacing.
No probs on the time, as I obviously would love all these issues above to be fixed asap.
Thank you for your time and diligence on this too.
Now some questions:
1) Can you please post the CAR for this Red X Palette bug so I can track it?
2) Is it possible to lodge:
@JG wrote:
3. Adding an Xctrl reference to a Class works fine in source, but broke my build at run time.
as a CAR as well?
I know that you have "solved" the issue I am seeing as it shows that in help, but I think this functionality is very crucial.
AQ mentioned that lodging functional issues as CARs is a good way to approach these things?
Could you please (insert begging here 🙂 ) lodge this as a CAR?
Cheers
-JG
Message 35 of 41
(2,423 Views)
I don't know how you got this filed as a bug.
I tried to do that in a Beta and it was deferred. eg. not a bug.
Ton
My LabVIEW Ideas
Message 36 of 41
(2,413 Views)
Hi Ton
Can you please specify which issue you are referring to (as their are four in this thread).
Also can you post a link so I can have a look?
Cheers
-JG
Message 37 of 41
(2,409 Views)
My issue was the missing indexing of xcontrols inside user.lib. It got a car (151138), which got deferred during a beta of LabVIEW (so I cannot share a link with you, I might be trespassing by posting this info).
Ton
My LabVIEW Ideas
Message 38 of 41
(2,395 Views)
Hello JG,
The CAR number for the red x glyphs on VIs in a user defined palette is 185059. Sorry about that. After doing some research on "Adding an Xctrl reference to a Class works fine in source, but broke my build at run time.", I found CAR 210033 that matches this description. I have added this forum post to it for there information.
Thanks again for being patience with us while figuring out this issue. I wish we had better answers then it's a bug but now R&D are looking into them so they can hopefully be fixed for future versions.
Hello Ton,
Thanks for posting this CAR number. I looked into this one and it is very close the same issue. I have added that information into CAR 236395 so R&D knows about it. Thanks again.
Jim St
Message 39 of 41
(2,377 Views)
Thanks Ton for posting.
As always, thanks Jim for your help.
Do CARs have ETAs attached to them?
Or is it wait and see when a new release/service-pack gets released?
Message 40 of 41
(2,371 Views)
