09-16-2013 04:49 AM
Hi guys, I want to realize a waveform graph that visualize the two signals (an array with the frequency information and another one with Amplitude information) that I have as inputs like in the figure attached.
Can you suggest me a way to do it? I tried with the build array function but it doesn't work.
Thank you
09-16-2013 04:58 AM
09-16-2013 04:59 AM
Hi you can use an XY graph for the purpose. attached an example
09-16-2013 05:18 AM
Hi guys. First of all thank you both for the reply. Well before to post I tried the XY graph but the result is shown in the figure.
The first For cicle give me the Freq and the Amplitude values but with three 0 at the end of the vector. I removed the three 0 with the second cicle.
09-16-2013 05:26 AM
09-16-2013 05:32 AM - edited 09-16-2013 05:33 AM
Hi Dennis, I have corrected the VI removing the second for loop by inserting Delete From Array Function.
Yep I saw the context help but I dunno how to solve the problem 😞
EDIT: i mean i know that it is a problem of array but i don't know how to change them in dimension
09-16-2013 05:35 AM
09-16-2013 05:42 AM
It says:
the tipe of the source is 2-D array of double
The tipe of the sink is 1-D array of claster of 2 elements
09-16-2013 05:49 AM
09-16-2013 06:50 AM - edited 09-16-2013 06:54 AM
Dennis can you give me an example because I don't understand where the problem is.
I think that the error is given by the fact that my array is displayed as column instead of row
EDIT:sorry my mistake!!!I used the build array instead of the bundle!!!crap!!! It was driving me crazy!
