Waveform Graph
Now that it works I saw this:
If I want to add a costant line to the graph how should I do?
I want to see a line that start from 47MHz and arrive to 74Mhz costant for all the range at -36
Message 11 of 12
(317 Views)
Adding another plot is where you would use a build array. Create another bundle with the separate x and y arrays and use the build array to add the previous cluster.
Message 12 of 12
(313 Views)
