View final (execution) front panel during edition
Hi all Labview users,
I'm currently developping an application with LV 2015, and i try to define and set correctly my front panel. Then i'm wondering one thing:
Is it possible to have a view of what the front panel looks like when i'll execute my application?
Because, when i work on  my front panel, i have the menu bar, the toolbar and others things, that i disable when my application run. So when i try to place my indicators and/or my controls, it is never very good because when i run my application the size of the visible front panel is bigger than the one in Edition mode.
I'm not sure if i'm very clear, but if someone knows how to have the same visible front panel in edition or in run mode, it will be very helpfull.
Message 1 of 11
(3,977 Views)
Try "ctrl-m"
Message 2 of 11
(3,970 Views)
Does pressing Ctrl+M resolves your problem?
Please let us know
Message 3 of 11
(3,969 Views)
Hi
Thanks for your answers.
I try the shortcut you've mentionned.
However there is the same problem.
I put some controls near of the top of my front panel. I check in Run mode (with Ctrl-M) that my control is still near of the top. It is OK.
But when i click on RUN, i show a gap between the top of the front panel (in fact the window) and my control. This gap is not visible when i checked my front panel in Run mode.
Message 4 of 11
(3,957 Views)
Have you tried to put you code aligned with the axis mark/(pane)!
Please share screenshot
Message 5 of 11
(3,948 Views)
Can you attach a VI that shows this behavior with the gap?
Message 6 of 11
(3,944 Views)
Hi
So i change my Vi in order to remove some private part.
Here's the main VI.
Don't worry if any buttons work. I removed or i didn't make the code yet.
For information:
 + i use LV2015 SP1 64bits
 + i use windows 7
 + my screen resolultion is 1366 * 768
When you open the VI :
 1/ type Ctrl-M
     You'll see a small white space between the top of the screen and the big black square.
 2/ Run the VI
     You'll see a bigger white space between the top of the screen and the big black square.
Message 7 of 11
(3,935 Views)
I believe it is because your custom window run time position is changing the panel size. Either set the custom size to the current size or check the box for use current panel size
Message 8 of 11
(3,930 Views)
Well, i'll update my VI and make some tests.
Message 9 of 11
(3,924 Views)
I've made some test, and the problem is not complety resolved.
Some times it works. But sometimes not.
If i move one controle, or if i add a new one, the problem is back
Message 10 of 11
(3,914 Views)
