Use Oracle database with LabVIEW
I am new to using Oracle database and i worked on MS Access database. I want to use Oracle database in one of our application to store the data and retreive data using SQL statements instead of MS Access. Plz give some suggestions which least version can i use? is there any free version i can get?. This i need to deilver along with the software.
Message 1 of 12
(9,054 Views)
Please
do
a
search
Option 1: Database Toolkit.http://sine.ni.com/nips/cds/view/p/lang/en/nid/209060
Option 2: LabSQL: http://jeffreytravis.com/lost/labsql.html
I will leave it to you to actually click on the links and read.
Message 2 of 12
(9,045 Views)
What is wrong with asking questions (even basic ones) on this board? Most if not all questions posted can be answered by searching or doing a little research. If you find these offensive, why answer?
Message 3 of 12
(9,040 Views)
How To Ask Questions The Smart Way
Because I like to help.
Message 4 of 12
(9,038 Views)
Accepted by topic author Rajashekar
Yes there is a free version called Oracle XE that works very well. In fact, it is intended for (what Oracle referes to as) OEM applications. It is free to use and there are support forums available that are also free. The free version has all the features of Enterprise witha couple limit: First, it will only access one core in your CPU. Second, the maximum data size is 4 Gbytes.
In terms of connecting to it, check out this discussion.
MIke...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 12
(9,032 Views)
PostGRES and MySQL are also some decent free databases. MySQL is now supported by Oracle and even if you go with the Enterprise Edition it is a cheaper alternative to Oracle.
Mark Yedinak
LabVIEW Champion
Message 6 of 12
(9,023 Views)
Is the question here what Oracle database to use, or is the question how to use Oracle with LabVIEW?
The last two responses seemed to be centered on the interpretation that the OP is asking what alternatives to Oracle to use. My interpretation of the question was how to use Oracle with LabVIEW. These are two different questions.
Message 7 of 12
(9,017 Views)
Yes they are, and in my post I answered both - at least to the driver level.
Obviously there are other questions like how to structure the interactions and how to design the database itself, but those can be sorted out best once he's got a database installed and is talking to it.
Mike...
PS: There is also the huge issue of translating the Jet dialect of SQL into the ANSI standard version that Oracle runs - potentially lots of fun to be had there...
Mike...
LabVIEW Champion
Message 8 of 12
(9,010 Views)
Thanks for your valuable replies. Actually we are working out for one of our project, there the customer is clearly indicated to use the Oracle database. Since i am new to oracle database i wanted to know which version of datbase to use and how cost effective it is. However the Database Connectivity toolkit can be used to communicate with Oracle database which supports OLE DB and ODBC. I just checked the Oracle website and found that the Oracle XE is free version which can be used.
Thanks and Regards,
Rajashekar
Message 9 of 12
(8,999 Views)
Yes the DCT can be used. But given the problems it can cause you might not want to. Plus the DCT is not free...
Mike...
LabVIEW Champion
Message 10 of 12
(8,995 Views)
