Undo annoyance
Is this just me but I am annoyed by this "feature" of the Undo:
When you undo something in a diagram that is hidden (for instance because it is in another case), you only get the "ghost contour" of what is restored. That's not very useful and I am wondering whether this is worth a suggestion (could not find one specific to that point).
Example:
WTH is that and where is it? Should I stop undoing and check all the cases to figure out where this stuff is hidden (and then how do I go back to the original case I was looking at?).
Message 1 of 16
(4,268 Views)
It's just you. Smiley Wink
I've seen that all the time, and frankly, it's never bothered me. What would you prefer it to do? Switch to the case?
Message 2 of 16
(4,251 Views)
I don't know. I am just pointing the annoyance. Other shall do the brainstorming.
I am just saying: what do I learn from this ghost contour? OK, let me rephrase this: what do YOU learn from it?
Message 3 of 16
(4,243 Views)
I don't really expect to learn anything from it. Clearly I had deleted something in that case, moved to another case, and did something else. I already know I deleted it, so it showing me the contour just indicates it's at that step in the sequence. OK. I don't really need it to show me anything else.
I'm just saying it doesn't really annoy me, and you just asked whether it annoys others. It might, but not me. Maybe I'm just feeling lackadaisical today. Smiley Happy
Maybe it would help if we had an Undo window showing the undo steps? Sort of like the one in Paint.Net. I think there may have been an idea about it, but I'm not sure. There were a lot of ideas tossed around regarding Undo.
Message 4 of 16
(4,237 Views)
You could certainly request that changing visible case (or event) operations are added to the undo buffer.
Message 5 of 16
(4,234 Views)
I had browsed this thread  before I decided to rant. Of course I totally support the corresponding suggestion. But that would clearly be a major rework... How long did we look for the Undo? LV 5? I am not sure I will still be programming when this stuff is going to show up 🙂
Message 6 of 16
(4,224 Views)
@ Darin.K: Care to expand?
Message 7 of 16
(4,228 Views)
Pretty simple.  Right now changing the visible case or event does not add to the undo buffer.  So if you delete an object, change visible case, undo you only undo the delete operation.  It sounds like you would prefer the first undo to change back to the original case and then have a second undo undelete the object.
It is always a balance between polluting the buffer and missing out on key steps.
Message 8 of 16
(4,226 Views)
Yeah, I guess it would do the trick. After all, every move of an object is tracked...
Message 9 of 16
(4,223 Views)
But it would even add another level of confusion " (and then how do I go back to the original case I was looking at?)", where at least you navigated back to the case, rather than mysteriously being transported through an unknown number of case.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 10 of 16
(4,211 Views)
