01-12-2016 08:37 AM
I'm currently using a Measurement Computing USB-2533 board (http://www.mccdaq.com/usb-data-acquisition/USB-2533.aspx) to communicate with a ESP 16HD pressure scanner (http://www.meas-spec.com/product/t_product.aspx?id=9311). When the board and scanner are hooked together, I can use a multimeter and see an appropriate voltage difference across the pins (that would be pin 2 Analog CH19 and Analog GND pin 5 on board J5).
But when I use the ULx tutorials and available resources to read data from the board, I specify for it to look at CH19 when creating the task but only insignificant numbers are returned (very small numbers).
One idea that I have is that it may not be referencing the same ground I was contacting with the multimeter leads. Any other insights?
See attached VI
Thanks.
J^2
01-13-2016 02:03 PM
Hi jsquared,
You will probably get more help/visibility on this post by if you repost it to the Multifunction DAQ board. I wasn't able to open your VI so I'm not sure how you're communicating with the device but in the meantime you may want to look at this KB http://digital.ni.com/public.nsf/allkb/2AAFB18B67617E2A862576C00059BA5B about acessing internal channels, you may be able to use this to reference the same ground pin as you did while taking the measurement.
Selene v.
Applications Engineer
