Touch Panel PC Labview with Thirdparty
dear NI,
                    I am using third party Touch Panel PC Windows CE5.0  ARM 9 based system. using TPC  - Addon labview i created the Exe. and i downloaded on the Touch Panel PC. but it does not work . it showing error  " E>BLOXX MEASUREMENT  is not valid Windows CE application". is it required any runtime engine?
Suggest me something..
Balaji DP
(2,279 Views)
Hi balaji,
Look at these links it may help you.
http://digital.ni.com/public.nsf/allkb/5E9796BD30A6C644862573860071EBE0
http://digital.ni.com/public.nsf/allkb/DE177828D27A14A48625734E00768B66?OpenDocument
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,248 Views)
What happens when you run a simple application? Like maybe a while loop with a random generator.
If you still get an error, do you have any other TPCs lying around (with a different hardware) that you can use to try out your application?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,242 Views)
