String constants resized - Bug
I have an issue with one specific VI, it I open that with LabVIEW 2009 SP 1, a lot of the string constants get resized until only the first character is visible:
I am not sure why it happens with this specific VI, but I can tell it's quite annoying to debug this kind of code.
Ton
My LabVIEW Ideas
Message 1 of 19
(5,753 Views)
Is this Winodows Vista or Windows 7 ?
I have seen bad font mangling happening on my Windows 7 machine.
I ask because the size of the "path property" node looks like what I have seen on Windows 7.
Ben
Message 2 of 19
(5,750 Views)
I have encountered this very annoying behavior when opening LV8.x VIs with LV2009 on WXP.
Message 3 of 19
(5,746 Views)
Windows 7, but to clarify, the font is not mangled. It looks like their is a 'Resize to text', witht the text length set to '1'.
Ton
My LabVIEW Ideas
Message 4 of 19
(5,709 Views)
Ton
Yes, this is exactly what I have encountered with WXP. A "Size to text" was needed to resize the constant in order to see the whole string again.
Message 5 of 19
(5,689 Views)
Hi TCPlomp,
In order to file a correct CAR (Corrective Action Request) for this kind of bugs, we need to have a VI to reproduce this issue.
Can you please post your VI, so we can verify and reproduce the problem?
Thanks in advance!
PeterS
Message 6 of 19
(5,676 Views)
Peter,
could you contact me via email?
Ton
My LabVIEW Ideas
Message 7 of 19
(5,660 Views)
I got a FPCPP error on lin 944 when using 'resize to text' and afterwards I could not start LabVIEW (have to try a reboot).
Initial Log in the Windows event log:
Naam van toepassing met fout: LabVIEW.exe, versie: 9.0.1.4011, tijdstempel: 0x4b47e0ad
Naam van module met fout: LabVIEW.exe, versie: 9.0.1.4011, tijdstempel: 0x4b47e0ad
Uitzonderingscode: 0xc0000005
Foutoffset: 0x0151332e
Id van proces met fout: 0x1940
Starttijd van toepassing met fout: 0x01cae969872ba726
Pad naar toepassing met fout: C:\Program Files\National Instruments\LabVIEW 2009\LabVIEW.exe
Pad naar module met fout: C:\Program Files\National Instruments\LabVIEW 2009\LabVIEW.exe
Rapport-id: 2ecaeea3-555d-11df-8f42-00235a05a8d2
Log of the crashe LabVIEW starts:
Id van proces met fout: 0xf40
Starttijd van toepassing met fout: 0x01cae969fa920d98
Rapport-id: 4274f129-555d-11df-8f42-00235a05a8d2
Ton
My LabVIEW Ideas
Message 8 of 19
(5,549 Views)
I've seen this occasionally too on LV 2009, win XP.
I don't use either the JKI state machine or the case selector plugin (which Ton suspected of elsewhere), so I doubt those are the cause for this.
___________________
Try to take over the world!
Message 9 of 19
(5,522 Views)
And I have seen it with a numeric constant.
Instead of showing it's value 1000, it only showed 0.
I didn't even know it was possible to resize a numeric constant.
Ton
My LabVIEW Ideas
Message 10 of 19
(5,449 Views)
