Stream 2 x 120 fps cameras to disk ... HDD can't keep up?
So I have two Basler firewire cameras.  Each camera has its own firewire-B card.  And I I wrote some LabVIEW software that can grab frames at 120 fps per camera.
But I am unable to stream to disk quickly enough to keep up with the frame grab.  Even if I use a producer-consumer architecture, my buffers end up overflowing.  Because I am logging from two cameras simultaneously, I am essentially streaming 240 fps to disk, and each image is color and 640x480.
Question:  any reccomendations on how to get around this?  I am curious if a new and fast PC with a super-fast HDD will solve the problem.  Or maybe even a SSD drive?
http://www.medicollector.com
Message 1 of 15
(4,513 Views)
It all depends on the data rate you have to stream. Different storages have different performance. Benchmarks are the key to get a feeling if a storage type (HDD, SSD, RAID) is sufficient to handle the given data rate.
Let's make a small calculation on your figures:
640 * 480 (Resolution) * 2 (32 bit color depth) * 240 (fps) = 147456000 B/s. This is round about 147 MB/s. Pure data without any additional information.
So you can see that even SSD will most probable be not sufficient (read something about 70-80MB/s for SSD writing), so you will have to use RAID.
hope this helps,
Norbert
EDIT: The transferrates for SSD is very different. Maybe, this chart helps a bit, even though it does not state MB/s....
Norbert
Expert: Geometry
Message 2 of 15
(4,510 Views)
My SSD drive at home got 415 Read MB/sec and 260 MB/sec write. Buy two of these and put them in raid0 and you got the double. Or you can buy a Revo Drive X2. Believe me, speed is not a problem for SSD!
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 3 of 15
(4,505 Views)
The problem is definitely the stream to disk rate, as others have said.  Two things are slowing you down - shear volume (about 75 MB/s for grayscale) and opening and closing 240 files every second.
One way around the second issue is to write everything to a single (or two) files, such as AVIs.  The only solution for the first issue is a very fast hard drive or several operating together to give you the high transfer rate.  I suspect several drives in RAID configuration would do the job.
Bruce
Bruce Ammons
Ammons Engineering
Message 4 of 15
(4,494 Views)
If you want speed...  1 Gigabyte Read/write!! Of course it costs alot, but it's the fastest thing you can get.
As budget disk I would have set 3 of these in raid0.
Even
Topro AS
Norway
Message 5 of 15
(4,492 Views)
Wow, thanks for all the tips everyone!  I really appreciate it.  Kudos will be distributed!
As Bruce mentioned, I was actually planning on writing all the images to two separate AVIs, so that will save on the open/close file operations.
To be honest, budget is not my biggest concern.  My goal is to make it work ... and to make it work reliably.  I also want to reduce the complexity (eg I'd rather buy a more expensive SSD drive than to purchase multiple drives and put them in RAID0).  So I'll probably go for a PCIe SSD drive like the models that were suggested.  But since my two PCIe slots are already occupied by the firewire frame grabbers, I will also have to purchase a new PC with three PCIe slots.  This leads to my next question:
I won't somehow overload my PCIe bus if connect two framegrabbers and an SSD drive to the bus?
Thanks!
Message 6 of 15
(4,476 Views)
Hmmm.  Interesting.  I just did a HDD test using Dacris Benchmarks.  It said my HDD can only do 31.4 MB/s which is a far cry from what I will require.
It is a 7200 rmp SCSI drive.
Message 7 of 15
(4,459 Views)
Multiply that by 2 (32 bit color depth = 4 bytes per pixel) --> you need a HDD speed of ~300 MB/s, considering nothing else needs access to this HDD at the same time.
Have a look at the following links for NI products covering this requirement (PXI):
http://zone.ni.com/wv/app/doc/p/id/wv-466
http://sine.ni.com/nips/cds/view/p/lang/en/nid/203949
Message 8 of 15
(4,449 Views)
Am I missing something. I come up with 589 MB/sec assuming (4 bytes per pixel, using only 8 bits per color)?
Message 9 of 15
(4,435 Views)
So what would be your calculation?
640 * 480 (Resolution) * 4 (32 bit color depth) * 240 (fps) ~ 295 MB/s
Message 10 of 15
(4,431 Views)
