12-31-2019 11:00 AM
I have generated a value let us consider as an indicator now when i run it for the next time the indicator shouldn't reinitialise to zero.Is there any possibility of doing so....
12-31-2019 11:10 AM
Save the value to a file. When the VI runs again, have it read the file and write the value to a local variable of the indicator.
12-31-2019 11:11 AM
Get the value and store it in a file (for instance an ini file) when you close.
Read the value from the file when you start and set it.
12-31-2019 01:45 PM
If you don't need to close and reopen the VI (more specifically if it won't leave memory between executions) then you could also consider Uninitialized Shift Registers as a possibility.
These are quicker and simpler to set up but are subject to the restrictions I mentioned - they will not retain values if the VI leaves memory.
