06-23-2022 10:24 AM
I am attempting to develop an automated system for brewing beer. When I add a timer circuit the timer will run, but it stops the daq from receiving the input signal from the thermistors. Anyone know how to fix this?
06-23-2022 10:41 AM - edited 06-23-2022 10:45 AM
You will soon be asked to post a code and preferably of a version that most can access, say 2018.
EDIT: Not a picture/ snapshot. But an actual VI. I do not think your question is detailed enough to be answered in a helpful manner.
06-24-2022 10:30 AM
You mention "state machine" in the subject, but we cannot even guess what the problem might be. What is a "timer circuit"?
Please attach your vi to hopefully make things a bit clearer.
06-28-2022 07:09 PM
I am building an automated system for brewing beer. I have 5 outputs (2 pumps, 2 valves, and a heating element) and two inputs (thermocouples).
I want to write a program that will operate like a state machine. I want it to get to a certain temp then hold it there for a set amount of time, then change temp and hold it for a new set time. The issue is when I add the elapsed time function it stops the thermocouples from receiving input signals. I will post my code below. Thanks in advanced for any help.
06-28-2022 08:08 PM
You have defined your states wrong. Essentially you stuck a wait for Time inside a state rather than defining your states as Start Process, Check if Process is completed.
I wrote this analogy some time ago to help illustrate how to define states and stare transitions.
06-28-2022 08:45 PM
I just want the input signals to run as well as the timer.
06-29-2022 04:00 AM - edited 06-29-2022 04:03 AM
Requested moderator to merge
06-29-2022 04:02 AM
