Schmitt Trigger
I like to do a Schmitt Trigger function with the VI in the attachment. I use LV 6.0.
Current function:
x <= 991             LED on
x >= 1008           LED on
991 < x < 1008   LED off
Desired function:
change over from x = 1007 to x >= 1008 LED on and by decreasing values LED on till X >= 1006
                        <___________________       LED on
____________|______>|                               LED off
1000            1006       1008
Any ideas?
Regards
ThomasD
Message 1 of 20
(14,657 Views)
If LED=OFF and value = 1007 then LED = OFF
If LED=ON and value = 1007 then LED = ON
If value => 1008 then LED=ON
if value =< 1006 then LED = off
Message 2 of 20
(14,647 Views)
Is there some text missing in your post? If not, yes, this is what I want to do but how to realize?
Message 3 of 20
(14,640 Views)
I don't have LabVIEW 6 installed but here is a picture.
Message 4 of 20
(14,632 Views)
Hi Odd,
thanks for your answer, that´s what I want.
I have modivied the VI, so there are now hysteresis for an upper and a lower value.
Regards ThomasD
Message 5 of 20
(14,581 Views)
_____________|_______>|                              LED off
1000            1006       1008
One simple translation into LabVIEW code is shown in the attached image.
Message Edited by altenbach on 12-20-2005 01:14 AM
Message 6 of 20
(14,574 Views)
Nice and simple!
Message 7 of 20
(14,559 Views)
Thanks a lot for yor design i think you help a lot of people
Message 8 of 20
(12,484 Views)
I would appreciate it if you can help here. I want to use Schmitt Trigger in my design. I am using a USB-1208FS DAQ to convert the analog signal from ultrasonic sensor to digital (0-5V). I used two digital output ports in the DAQ, each port work individually (0-5V). I calibrate the sensor to get the distance. I used the calibration equation in labview to get the distance. The threshold I am looking for is the heights of plants (0-6 inch is weeds), (6-12 inch is plants). So, less than 6 inches is weeds, and greater than 6 inches is plants. How can I use the Schmitt Trigger to control the digital output ports? Attached is the VI I am working on. Thanks
Message 9 of 20
(10,913 Views)
Mazin,
It probably would have been better to start a new thread than to tag on to one that is 8 years old.
Have you tried the code that altenbach suggested?  It is not completely clear what you want the Schmitt trigger to do. How much hysteresis do you want?
Lynn
Message 10 of 20
(10,898 Views)
