Scale object with panel programmatically?
Is there a way to enable the "Scale object with panel" property of a front-panel object programmatically?  It doesn't appear to be possible, but I wanted to check before giving up and making a hack finding a different solution.
Message 1 of 9
(9,045 Views)
Accepted by topic author ronbrown
I think that the pane "set scaling" method will work for you.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 2 of 9
(9,034 Views)
In what version of LabVIEW is that available?  We're using 8.5 and I don't see that option on the Pane's property node.
Message 3 of 9
(9,017 Views)
vt92 wrote " think that the pane "set scaling" method will work for you"
I can't count how many times I failed to find a method when using a property node. Smiley Wink
Ben
Message 4 of 9
(9,008 Views)
Ah.  That explains why I was so confused. I looked at the above image and INVOKE NODE looks exactly like PROPERTY NODE.  While I appreciate the (somewhat sarcastic) answer, I think it was an easy mistake to make for someone who hadn't used invoke node before.
Thank you for the assistance.
For future reference to anyone who searches for this topic:
* On the block diagram, go to Application Control Palette, and place an "invoke node"
* Right click Invoke Node, and  Link To -> Pane -> Pane
* Select "Set Scaling Mode" and wire up as seen in the above image.
Message 5 of 9
(9,006 Views)
Hi Ron,
I am sorry if my reply sounded sarcastic. Smiley Sad It was not intended to be so. Please accept my appology. I have many times looked for a method in a list of properties because most of the operations associated with LV objects are properties and the list of methods is relativle small. It is only after I don't find it there that I remember that is was a method and not a property I was after. Hopefully you will not have that problem. I would be fooling myself if I entertained that idea. Smiley Happy
Thank you,
Ben
Message 6 of 9
(9,001 Views)
Not a problem.  Thanks for the reply.
Message 7 of 9
(8,997 Views)
What can be the reason why my method looks differently?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 8 of 9
(5,786 Views)
there's an implicit and an explicit version of many property or invoke (method) nodes:
https://labviewwiki.org/wiki/Control_References#Implicit_vs._Explicit_Linked
Further more, there are some property nodes which are only available in the IDE, so you can't use them in an .exe
https://www.ni.com/docs/en-US/bundle/labview/page/enabling-vi-scripting.html
https://www.ni.com/en/support/downloads/tools-network/download.labview-vi-scripting.html
Message 9 of 9
(5,738 Views)
