07-04-2015 01:50 PM - edited 07-04-2015 01:59 PM
I am using Keithley 6221 Current Source and 2182A Nanovoltmeter.
I am using RS-232 serial bus and trigger link to communicate between 6221 and 2182A and GPIB to communicate between 6221 and Computer.
Kindly tell me how to get data from this setup for a Current-Voltage(IV measurement).
Sweep is working fine but I am unable to save data in computer.
If possible a demo LabVIEW vi will be very helpful which can to save 100 points.
Vaibhavi Negi
Research Scholar
Delhi; India
07-04-2015 02:05 PM
07-04-2015 02:28 PM
This is a default setup of keithley 6221 and 2182A Instrument. and Sweep mode, Delta Mode, Pulse delta and Differential Conductance work with this setup.
There is a software http://www.keithley.in/base_download?dassetid=16067 provided by keithley run on the discussed setup. But it is an exe so we don't have access to code and in sweep mode we can see data but can't save it. So I am asking for help if any one has the LabVIEW code to get data from Sweep mode.
07-04-2015 02:35 PM
07-05-2015 12:57 AM
It is a demo software.
And what is the logic behind this functionality that you can measure really fast but you can't save the data.
If we can't save data then why one should use it and why Keithley made this.
We can see data it the demo software soon implementing it on our own program definetly we can save it.
I am asking If someone has done this before then please tell me how?
07-05-2015 01:15 AM
02-26-2022 10:55 PM
I am also facing the same problem sir ..How do you rectified it?Thanks in advance
