06-01-2010 10:47 AM
06-01-2010 06:39 PM
I couldn't find anything either so I ended up coding my own version - this was also handy as I needed to acquire some other signals from different devices. Unfortunately its not something I can share on this board.
One place you could look is that there is a VI that takes two waveform inputs (or arrays of waveform inputs - it's polymorphic) - if you use this + some logic to get the waveforms via some other means (such as the generate chirp function + DAQmx VIs) you can make something similar to the toolkit.
Long and the short of it though: SVT VIs are great for basic (ie 1 response) but for anything remotely complicated you need to roll your own.
02-28-2011 01:03 AM
The SVT swept sine only allows one sine to be sweep in and one out. Is it possible to sweep in another sine tone.
03-01-2011 11:26 AM
As mentioned above the SVT functions are built for single sine wave inputs, other functions can be used in conjunction with these functions to customize the configuration.
Justin
