07-26-2011 03:13 PM
Hi Dear TREX,
i am unable to understand how to detect Disconnection during Read Time out. Kindly help me in this.Thanks
Regards
awais qureshi
07-26-2011 03:54 PM
You can't unless the other side of the connection explicitly sends a TCP-RST or TCP-FIN. If neither of these are sent there is no way for the your TCP-Read to detect the connection has been closed. This is not an issue with LabVIEW but how the TCP protocol works.
03-21-2012 05:11 AM
can u tell me how to achieve BT communication from laptop for remote control of sbrio 9631.
03-21-2012 09:50 PM
Dear srabot,
BT VIs are available in Labview which may advertise laptop BT module using UUID. Also you need to uninstall any other OEM driver, only BT driver of Microsoft window is required to accomplish BT communication using BT VIs of LabView. Good example are available in Labview as very for making Laptop master or slave.
Good luck
05-05-2014 09:43 AM
i am junior and i have many trouble when i start with labview
i have used tcp to connect pc-pc with utp capble but,do it as wifi,i cannot
so,can u tell how to use tcp make a wifi connection pc-pc
thanks so much
05-05-2014 11:07 AM
LabVIEW does not know the difference between wired and wireless ethernet.
Please start a new thread and provide more details on your network configurations.. For example are both computers on the same subnet? Can they ping each other?
05-05-2014 07:26 PM
thank for your care
with microsoft menthod,i can creat a network by wifi(ad hoc),my PC can ping to each other(same as utp caple),so,i hope labview can distinguish from wired and wireless by somethings.i dont know it,like as BT labview know is as wireless
05-06-2014 09:41 AM
Dear review my attached paper to see can you find some help...
Regards
05-07-2014 12:17 AM
that 's amazing.I saw your Screenshots of MP Wi-Fi application .So,was it programmed by labview? it looks like connectify sowfware.How can i creat it by labviewand use it to connect wify PC-PC?.Which toolskit or module sowfware i needs install?.Sorry for my annoyance,i am a junior and it make me get excited ,but i dont know how to start
thanks for your share and hope for your response soon
01-18-2017 06:12 AM
Hai friend in trying to send using bluetooth.. can u send me ur program ?
