Output to trigger 120VAC Solenoid valve
I have 4 solenoid valves 120VAC, working at 6.1 watts, requiring 0.05 amps. I want to control them from labVIEW via a DAQ hardware device.
My doubt is if there are hardware devices out there which give that much output to trigger a solenoid valve ON/OFF?
If NO, is there any way that I can achieve this?
Thank you.
Message 1 of 9
(5,333 Views)
Have you tried a digital output controlling a relay?
Jim
LV 2020
Message 2 of 9
(5,324 Views)
Thank you for the reply Jim.
I haven't tried it. Can you please explain in detail.
Message 3 of 9
(5,322 Views)
Accepted by Seema
A digital output device (DO) is controlled by your PC to turn a DC voltage on and off.  A relay is a switch that uses an electrical input, typically low voltage but not always, and usually low current (like from a DO) to switch a higher voltage and/or current signal - like your 120VAC to control your solenoid.
Jim
LV 2020
Message 4 of 9
(5,311 Views)
Thank you Jim
Message 5 of 9
(5,304 Views)
hi
just use a relay circuit to switch any type of inductive load .you can get a lot of relay circuits from internet ....if not found then i will try to send u....
bye bye
Message 6 of 9
(5,292 Views)
Solid state relays (SSR's) are a good way to go, they can trpicially be driven by most DIO lines and create no inductive spike when turned off. They also come in zero-crossing turn on/off styles for a clean power on/off transition on the AC side.
If you do end up using a coil based relay, be sure to a reverse biased diode (1N4004 work well) to prevent damage to the DIO line when turned off (aforementioned inductive spike).
-AK2DM
Message 7 of 9
(5,285 Views)
I have the exact same problem as the original poster of this thread. Does your offer stilll stand? I did search the internet for relay circuits and did not find any circuits relevant.
Would you be willing to try to send me circuit diagrams of a relay triggering a solenoid?
You would be helping a college student project!!!
Message 8 of 9
(4,628 Views)
Try This
Jim
LV 2020
Message 9 of 9
(4,571 Views)
