01-19-2007 11:29 AM
Description : See attached VI. While in the “TCP Read” loop, the Ethernet connection is physically disconnected.
Problem : No Error 66 is returned from the TCP Read.
01-19-2007 12:16 PM
01-19-2007 01:10 PM
Thanks for testing this. As it turns out when I disconnect the Ethernet cable I do indeed get the Error 66. Our real test is a VME reset (not disconnecting the cable) which resets our target. After doing the VME reset, Windows (host) recognizes that the ethernet connection is lost, but the TCP read (sample program I posted) on the host does not. We're now looking into jumper settings on our target board to see if that is where the problem lies.
Thanks again.
01-22-2007 10:31 AM
01-22-2007 06:22 PM
01-23-2007 08:46 AM
Hello -
Actually, the timeout error is 56 and I am trapping that. When I call TCPRead, I need to know if the connection has been closed by the peer (66) - this is what takes 5 or more seconds.
01-23-2007 11:03 AM
Hi Red Sox Fan,
Thanks for clarifying for me. The reason it takes so long to report a
connection loss is because TCP is a lossy communication protocol. If
packets are lost, they are sent again. There must be time to verify that
the missing information is due to a connection loss and not just dropped
packets due to the lossy nature of TCP.
Please let me know if you have any further questions, and have a wonderful day!!
01-23-2007 11:19 AM
Thanks for your reply -
I still have a problem with this. If I disconnect the ethernet cable, Windows immediately displays a message that a network cable is unplugged, but the TCPRead takes over 5 seconds to report an Error 66. I have started using a Windows API to determine if the NIC is disconnected - which works great (takes about 45 microseconds). However, I am connected to a target multiple IPs and need to know if one of the connections is closed. By the time the 5 or more seconds is up and the Error 66 occurs, the individual target processor has already rebooted - which for our application is NOT a good thing.
01-23-2007 11:27 AM
Just a thought....
The Watch-dog timer may be useful.
Done thinking...
Ben
01-23-2007 12:23 PM
Rolf has more details in this crosspost.
David, when crossposting it is considered polite to provide a link so that people can see what other people already said and not waste their time.
