Mixed Signal Graph control: cumulative issues
Mixed Signal Graph control (MSG) is a really powerful control to easily present data, but since it has been introduced (LV 8.0 I think) it hasn't been developed a lot, so in LV 2011 there are some open issues (bugs, requests, ...). Some of them have alrady been posted, but apparently never considered...
  • programmatically se the group names (or here)
  • plot legends not deleted when the graph is cleared (see here)
  • bug in changing plot area height (see here)
  • when a MSG is customized, adding new plot areas doesn't retain the settings for plot color (white is taken) and grid color (grren) - see here
  • cursor events missing (Cursor Grab - Cursor Grab? - Cursor Move - Cursor Release)
  • a Mixed Signal Graph control with "system" theme also in the plot legend tree (see here)
  • add plot visibility checkbox (like other graphs)
  • add a way to programmatically remove a plot from the graph (see here)
I hope this issues can be fixed in the next LabVIEW release.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,330 Views)
Thanks for your feedback. I will take a look at these issues and see what features we can add in future releases. You will be happy to learn that the bug in changing plot area height has already been addressed in the next release.
(3,307 Views)
(3,307 Views)
one more bug:
  • when a MSG is customized, adding new plot areas doesn't retain the modified splitter height (the splitter is the element between two plot areas, that you can drag to resize the plot area height) - the 6 pixels default is used
Vix
Using LV from 7
(3,292 Views)
