09-18-2012 07:25 PM
I've run into the same error today after saving a top level VI in LV2009 (9.0, Professional Development System, 32bits runnning on a 64bits laptop.) The error was "labview load error code 3". The trick of modifying the .ini file was NOT working for me either. I would get the exact same error.
My solution was to open the VI in LV2011 and Save it for LV2009. I had to resolve a few conflicts but that was overall pretty straightforward.
12-03-2019 01:28 PM
I was making a VI in one of my machines with Labview 2011, and got the wiring issue. The code is no longer opening in Labview 2011.
I try to update to SP1, gave me license issues.
I open it on Labview 2012 SP1 and got the same error.
Could some one help me out with this VI?
Attached
12-03-2019 01:29 PM
It did not work for me with Labview 2012.
Could you revise my VI and fix it?
Gaston Tudury, PhD
12-03-2019 01:33 PM
12-03-2019 01:45 PM - edited 12-03-2019 01:46 PM
Here you go. Saved for LV12, missing several subVIs.
12-03-2019 01:46 PM
What you mean by SCC system? Sorry, unfamiliar with this acronym.
12-03-2019 01:47 PM
Thank you very much!
Could you let me know what you did to fix it?
Gaston
12-03-2019 01:51 PM
Hi Gaston,
It's "Source Code Control". SCC is also mentioned in the LabVIEW help and LabVIEW options…
12-03-2019 02:05 PM
12-03-2019 05:46 PM
I was not able to open it with Labview 2012 myself...
Someone also answer me that could not open with Labview 2019... (you could see that on my other post for help!).
