03-11-2013 09:05 PM
Thank you
07-25-2013 07:59 AM
Was able to run labview 7.1 Thanks!
01-17-2014 03:09 PM
I have Labview 7.1 installed and running in windows 7 64 bit. But the Database examples were broken I am looking still for a fix.
02-12-2014 01:15 PM
Please review related issue regarding running older LabView versions on Windows 7 but with the addition of Ni-DAQ hardware, here.
02-13-2014 06:42 PM
As mentioned previously in this thread, LabVIEW 7.1 is not compatible with Windows 7. The earliest compatible version would be LabVIEW 2009 SP1, so if you have that version I would definitely recommend using it. As far as the Database Connectivity Toolkit goes, it is not supported in the 64-bit version of LabVIEW. However, it will run if using 32-bit LabVIEW on a 64-bit operating system. Please see the links below for more information.
Windows Version Compatibility: http://digital.ni.com/public.nsf/allkb/B972242574D4BB99862575A7007520CB
Product Compatibility for Windows 7: http://www.ni.com/white-paper/10383/en/
Myriam
02-13-2014 06:52 PM
I started this thread some time ago and have learned a number of things since. It is not worth holding on to legacy software and hardware in most cases.
If you are really stuck on 7.1 for other reasons, support for XP has just been exented by Microsoft for another year, so stick with that until you get up the gumption to move forward. You really won't regret it!
02-13-2014 07:12 PM
The biggest reason to hang on to legacy software and hardware is if that code is "configured" and "released" for a production environment. Going through all of the effort to re-qualify new hardware and software can take a lot of time and cost a lot of money.
08-14-2014 03:12 AM
I have many PC and until recently I haven't got much problem with installing Labview 7 into win 7 32bit.
Now probably the drivers have ben upgraded and installation is no longer possible.
I realised that LabViee itself is not problematic. Problems begin with installation of drivers (MAX).
Therefor I used third party visa librarries and it works.
08-14-2014 04:09 AM
As does maintaining legacy code and non existant drivers, i recently spent the better part of a week to get an old system running with 7.1 which was needed since it used an old 1200 card (which also needed some hacks as i had to use Daq6) ... So 1 week of work compared to a ~600$ card and a days work to upgrade, which is better?
Both needed the same verification as it was due to a XP->W7 migration.
/Y
08-14-2014 06:28 AM
And then one of the production testers goes down because a legacy piece of hardware died and you have no more spares and all the replacements for that equipment only supoort the last two Windows versions. Now production is down by let's say 25% for weeks because one of the four testers is down and being used for development and qualification that you could've done offline and at your leisure.
