03-09-2011 07:36 AM
09-26-2011 07:17 AM - edited 09-26-2011 07:18 AM
LabVIEW supports OPC UA with NI LabVIEW OPC UA APIs https://decibel.ni.com/content/docs/DOC-16930
11-10-2013 05:55 AM
HI, I'm trying to connect to an Arburg injection moulding machine from Labview 2013. The machine has got an OPC UA server running and is configured with TCP/IP, I've connected using UAExpert but not LV. NI OPC doesn't seem to detect either the Arburg OPC server or the UAExpert OPC server. Any suggestions on how to resolve this would be welcome.
regards
ER
03-17-2015 08:53 AM
Did you ever figure out how to communicate with the Arburg using NI OPC UA? We are running into the same problems.
11-23-2016 09:36 AM
There was an issue with the Labview driver. I was using an older 2011 version. It is fixed in the DSC Module 2013.
