01-25-2018 06:48 AM
I'm pretty sure there are people using CP1251 out there. Either they gave up, or they solved this problem. Would be nice to get some insight from them.
01-25-2018 07:22 AM
02-19-2018 01:49 PM
I have tried other things but no luck.
Maybe this is related to LV installation?
02-19-2018 11:31 PM
Hi pawhan11,
I tried different way to do a unicode conversion for UTF16 which works fine till U8, Finally i went with Excel VB macro function and embedded in LabVIEW to RUN Macro and read back Unichar Values from excel
03-12-2018 01:14 PM
Thanks for reply.
Unfortunately installing excel on all possible machines is not an option only to provide translation.
I no longer work on this project but it would be nice to find solution, or logical explanation why this does not work. i will give it another try with clean os and clean LV on other pc.
03-13-2018 12:39 AM
Excel has a exact function for Unicode Conversion, whereas LabVIEW is not supporting even when Unicode= True is given in LabVIEW.ini.
LabVIEW Works fine if your Unicode is U8.
