Yes, in the facade VI you have a number of different events. One of them is called Direction Change. It fires when the XControl is loaded into memory, or is changed from a control to an indicator, or vice versa. Put logic in that event that forces the xcontrol to be a control if it's set to be an indicator.
Mike...
