10-15-2012 07:15 AM
Is there a method in labview to dynamically save and change the monitor resolution under program control? I have another application that runs on another monitor. I would like to change the monitor resoultion to 640x480 on program startup, and then restore the monitor resolution back to the user's settings on exit. Can this be done?
10-15-2012 10:04 AM
10-15-2012 10:09 AM
Have you already done this manually? I've seen Labview scale front panels very strangely when changing resolutions...
10-15-2012 06:39 PM
If you're using MS Windows, yes, you can do it with Windows API.
Not sure about other OS.
