09-01-2006 08:37 AM
09-01-2006 11:11 AM
You should be able to use the channel property node, and wire the global channel constant to it.
Paul
09-01-2006 11:14 AM
Also the niDAQmx system property node should return an array of all global Channels (as well as other system info)
Paul
09-01-2006 02:04 PM
08-03-2015 01:01 PM
Paul,
I can access basic properties using the approach you described, but do you know how to get the units from the global virtual channel? Say I had a general appliance for reading in load cells, and I wanted to have the axis labels in a graph show the units of whatever load cell had been selected.
08-04-2015 01:08 PM
Since this was posted on an older forum post, it will not be visited as frequently. If you repost this on a new forum thread you will get a better response from the community.
08-05-2015 12:32 PM
This is kludgy, but it works for AI channels.
08-05-2015 07:41 PM
That's awesome. Thanks!
