How to highlight a cell in a table
I have a 2D array of numbers that I'm passing through a number to string converter and then passing to a table.  I am wondering if there is a way that I can make any cell which contains a number over a certain threshold blink... I realize the values in the table are strings so I'm guessing maybe doing a find max in array and then somehow tracking the index for that value and making the cell blink?  I'm not even sure if that is possible.
M
(3,618 Views)
(3,612 Views)
Thank you, that worked, but now some of my cells keep the blinking color value when I rerun the program... my old max value cells are still highlighted.... do you know how I can convert them all back to their default background colors....
thank you
(3,559 Views)
Hi Monse,
to reset all, conect a cluster constant with the values "-2" and "-2" to the active cell property. It will select everything (see the content help of a table for more about it). After selecting all choose the new color.
Mike
(3,556 Views)
Much thanks, appreciate your help!  I was about to loop through each cell and set each one back individually.
thanks,
M.
(3,553 Views)
