Well - I know how to create a shortcut menu for a control, but how is it created for a pane? There is the possibility to add an event case for a shortcut menu linked to a pane (see picture), but how can I create this menu?
Message Edited by becktho on 08-01-200611:32 AM
Using LV8.0 -------------------------------------------------------------------- Don't be afraid to rate a good answer... 😉 --------------------------------------------------------------------
I don't know how to create a static run-time shortcut menu, but a dynamical creation should be possible in the same way as is demonstrated in the example code "<labview>\examples\general\Run-TimeShortcutMenu.llb\Run-Time Shortcut Menus.vi" for the shortcut menu of a control.
So, does anybody know how to access the menu editor at edit-time to create a static shortcut menu?
Well this works, but I'm rather looking for the static way. Maybe I did not write clear enough what I wanted to know.
