12-10-2008 03:16 PM
Try to set the initial position for a .net container, but seems no way to create a property node for the container (with an Textbox object).
It can only be done when container is empty. I wonder why? Do I miss something?
12-11-2008 10:11 AM
Hey zou,
I just created a .NET container and inserted a textbox into it. However, I had no problem at all with creating a property node for the occupied container. All I did was add a blank .NET container to the front panel. Then Iright clicked inside the container and added the textbox. Once I added the textbox I was able to create a property node on both the frontpanel and the block diagram.
As a side note I am using labVIEW 8.6, but the version shouldn't matter for this.
12-11-2008 10:34 AM
Is that property node for the .net object (textbox) or for the .net container?
Thans for reply.
George
12-11-2008 11:32 AM
If you right click on an empty container or a container with an object in it, it has the same available choices to select. However, if you create a blank property node on the block diagram, and wire up the .net object to it, you will see a much different list of properties.
So, the property node created from right clicking a .NET container will be for that container, even if there is an object inside. To create a property node for the object, you must wire the .NET object to an empty property node on the block diagram.
12-11-2008 12:23 PM
