04-22-2009 11:04 AM
I have a 6-element cluster which i need to change into an array for part of the VI process. This i can do, but then i need to change it back into a cluster of the same type to be used elsewhere. When i change the array back into a cluster, i end up with a 9-element cluster, which of course, is not compatible!
I enclose snapshots of the context help of the initial cluster, the intermediate array, and the final (wrong) cluster. In reference to the pictures, the length of the 1-D arrays and the values within them are the only things subject to change.
Please could someone help by suggesting ways of getting round this problem. Thank you
04-22-2009 11:09 AM
PLEASE do not post bitmaps by simply chaning the filename's extension to .jpg. Doing so does not change the filetype. There is a good reason why the forums software does not allow bitmaps, and that's because the file sizes are huge.
To your question: right-click on the Array to Cluster function and select "Cluster Size" from the popup menu to set the size of the output cluster.
04-22-2009 11:17 AM
