How do I export a panel image in vector format directly into a Word document?
I want to create a panel, with several graphs and text and numeric indicators, and export that to a vector-format image, such as DXF, wmf, or emf, so that it can be loaded into Word.  If I use BMP or other raster-format images, then the resulting printed picture is very coarse.  I want to use a vector format so that when Word prints the document it uses the native printer resolution.
Is there any way to programmaticaly output a panel to a vector-based image format?
(3,159 Views)
There is a private (read: undocumented) method for a VI called "Print: Panel to Postscript". Would this be an acceptable format?
Message Edited by smercurio_fc on 05-09-2008 10:06 AM
(3,147 Views)
Thanks for your response.
Yes, Encapsulated Postscript would be fine.  I just have to be able to cause the panel to print programmatically, specify the eps file to be written, and have it write without any user intervention.  Is this possible?
(3,122 Views)
Err... yes, with that method that I mentioned:
The individual items are all in the Application Control palette. As I indicated, this is a private method, so it's not documented.
Message Edited by smercurio_fc on 05-09-2008 12:17 PM
(3,118 Views)
