12-06-2014 12:27 AM
Hi all,
I am actually working in a high speed vision application - I case of remote debugging I know that I need a high speed Internet connection - but is there any way to solve this issue with out high speed Internet ?
my Internet connection speed is 8mbps.
12-06-2014 11:14 AM - edited 12-06-2014 11:15 AM
I'm sure there are about umtien ways to solve this but it will require instrumentation of the remote side in a way that allows you do let it run at full speed without transfering all the data back and forth over your slow internet connection.
There is really no other way around this. You simply can't force huge megapixel images through a 8Mbps link in realtime. Sometimes development of an algorithme is the easier part of the task. Instrumenting it in a way that you can debug it in a meaningful way is the real challenge, even if you don't have a slow network connection where your debugging has to funnel through.
