How can i save a 1-d array of waveforms in excel
How can i save a 1-d array of waveforms in excel. The array is coming from a vi that reads and graphs a wav. file
(3,413 Views)
Is your data type is numeric?
Try this one!
You can save with date and time.
KRAZE4LV
You can pay by Kudo!
(3,404 Views)
Accepted by navident
Hi Navident,
                    Before Creating the excel sheet keep in mind, you can not configure Excel to exceed the limit of 65,536 rows and 256 columns in Microsoft Office Excel 2003. I hope ths one will help for u
Siva
Sivaraj M.S
CLA
(3,403 Views)
the problem is that what I would like to saved in a excel is a sampling I'm doing... The problem comes because I have a function that save it, but only the samples showed in the graph (for example, 1 to 100).
The total of smaples are 6096, so I don't know how to save all at once.
If somebody could helps me, I will be so thankful!
Thanks!!
(3,322 Views)
Hi mlop,
I would need to know a little more about how your program is put together to say for sure, but it sounds like you are saving to the file outside of a loop and the data you are passing outside of the loop is only the last 100 samples.  You could either write to the excel file inside of the loop or make sure that you pass all of the data outside of the loop.
Have a great day,
Chris V
Applications Engineer
(3,295 Views)
