11-14-2008 01:03 PM
How can I separate Left and right audio channels in labview 8.5 tia sal22
Greetings All
I have a working Labview vi that converts a math formula to an audio signal. I would like to have the right and left audio channels playing different math audio signals is this possible?
Example
Right channel -> plays the audio signal created by a math formula
Left channel -> plays the audio signal created by another math formula with adjustable phase control
I’ve included a VI with a working audio and math formula but I’m not sure how to separate the left and right channels.
I’m using labview 8.5
I looked up a similar question on the support board and it said” use an instance of the the Sound Output Write that has a 1D waveform data type input (i.e. Sound Output Write (DBL)). Each element in the array would correspond to a channel.”
But I’m not exactly sure what he meant. I’m using a formula to generate the wave file
Tia sal22
11-14-2008 01:13 PM
11-14-2008 01:19 PM
>You've got a single math formula. If you would create another audio signal, convert that to a waveform, and use the Build >Array function, you would have a waveform array with 2 elements in it - a left channel and a right channel.
Can you point me to an example?
Thanks for such a quick response 🙂
11-14-2008 03:04 PM
I don't understand what kind of example you want. You originally stated that you were going to create:
You have not done this. You only created a single channel with your single math forumula. If you had 'another math formula' like you stated and created the waveform data type like you already did for the first channel, all that you would need is the Build Array function.
11-16-2008 07:10 PM
11-17-2008 01:06 PM
Their must be some type of misunderstanding I'm not trying to mix the two mathscript signals together I'm trying to have them play separately on the left and right mono channels. see example below
Does this make sense? I'm trying to increase the number of output analog signals I can use by separating the stereo channels into a one right and one left mono channel. So instead of just being able to use one stereo channel I can use 2 mono channels (the right channel and the left channel) Sorry if this wasn't clear before
tia sal22
11-17-2008 01:39 PM
There is no 'mixing' if you create a 1D array from two separate formulas. If you add a second formula and build an array as shown, you would have a left and right channel. Have you even added a second formula to your VI and tried what has been suggested?
12-13-2008 09:07 AM
Sorry it took so long to get back. Here's the new VI with it splitting out the left and right channels.
I'm using a Gigaport HD 8 output usb audio device but I'm experience clicks and pops. I increase the buffers
but I still get the clicks and pops. I know gigaport HD can use ASIO drivers which most likely would solve the problem but one needs to code in C for this which I'm not proficient in. Can someone recommend a work around to prevent this clicks and pops, can I somehow change my VI to fix this? Does anyone have a VI that will allow access to the ASIO latency properties?
I'm using labview 8.5
And a gigaport HD which is a USB audio device which outputs 8 analog signals (it is ASIO compatible)
tia sal22
12-13-2008 01:36 PM
12-15-2008 03:38 AM
