Hello Guys! Do you know how to put these every blocks in this Vi for a corectly function?
(431 Views)
(429 Views)
Hi neaua,
Instead of posting the same question twice you should explain the expected "correct" function!
(420 Views)
Let me explain in more detail.
I have a bachelor thesis based on image processing in a canteen.
Initially I used NiVision Assistant, where I created a script using the 'Color classification' function, where inside it I created classes for the types of food and in each class I created new samples (a CLF type document was created).
Then I exported everything I did in NiVision, in Labview as VI.
My problem is that I don't know how to create/delete new classes directly from VI.
I will also leave you the archieve.
(321 Views)
