07-24-2009 09:27 AM
Could you post a screen shot of your GUI so we can see what you are working on?
Thank you,
Ben
07-24-2009 09:44 AM
Do you see the difference between the 2 images?
The titles speak for themself...
07-24-2009 10:00 AM
I just found out that it is also related to the refreshrate. So when a change
the time to refresh I can reduce the cpu but only if I set it on 1 second. If I
set is on 0.5 sec it has the effect of 60% all visible and 15% bottom not
visible.
07-24-2009 10:20 AM
This is probably the last I can add to this riddle. back in about LV 6.1 i noticed an issue with LV controls that had tip-strips defined would cause a spike in CPU when they where hidden. Do those buttons at the top of your screen have tip-strips?
I watch this thread to see what NI has to say about those last 3 mm.
Ben
07-24-2009 10:23 AM
07-24-2009 11:10 AM
Sorry that is my fault! Copy paste error in paint!
Nop no tip striping on the buttons. Eventually the programma runs fin with the delay.
But it be much better if it runs smoother!
Thanks for the replies so far!!
