Disable Text Selection on FP Indicator
This is asked in the spirit of making an appealing UI. I have a text box that displays various bits of data. That part works fine. What I'd like to do is make it impossible for the user to select the text within the box. A mouseclick inside the box would behave like a mouseclick on a vacant part of the UI window.
Right now, I'm fooling around with the "Get Image" invoke node with the intent of creating an image of the indicator and then displaying it instead. Is there an easier way?
(4,512 Views)
Accepted by B_Strange
Just disable it.  If you always want it that way, then right-click on it and choose Advanced->Enabled State->Disabled.  There is a similar property node if you want to do it programmatically.
(4,490 Views)
Crossrulz' answer is better, but this is what I immediately thought of:
Jim
(4,485 Views)
@crossrulz wrote:
Just disable it.
I can't believe I didn't try that. Thanks.
(4,474 Views)
