Define the number of single retriggerable pulses
Hi everybody!
I generate single retriggerable pulses using a PCI-6602 and BNC-2121 Box (sent to my spectrometer) for my data aquisition.
For every trigger signal one spectra is aquired by our spec. It is very important to have a defined number of spectra, therefore I have to define the number of pulses in a retriggerable single pulse task.
Unfortunatly it isn't possible to use a pulse train instead because the jitter of my source is to high so that each pulse has to be retriggered.
Is there a way to do this?
Thank you very much for your help!
(2,628 Views)
Hi Konradeo,
it is a little bit difficult to understand, what du you want to accomplish. It would much more easier for me and the other forum user, if you could provide use your LabVIEW-Code and a sketch, what du you want to output with your PCI-6602.
(2,579 Views)
