11-23-2009 01:07 PM
Did you know you can configure VIs on the palettes to drop the contents of the VI, instead of the VI itself, when dropped from the palettes or Quick Drop? When you are editing the palette file that contains the palette VI in question, you can select Place VI Contents in its right-click menu to enable this functionality:
Some notable Place VI Contents VIs you might see in the LabVIEW palettes include the Word Constants (seen above), the JKI State Machine, and even the True Constant.
Historical Note: Place VI Contents VIs used to be called Merge VIs. But when we added the ability to "merge" VIs in LabVIEW 8.5, the name was changed to Place VI Contents to avoid user confusion over the two very different features.
11-23-2009 01:25 PM - edited 11-23-2009 01:26 PM
Place pre-formed structures quickly with Place VI Contents...
11-23-2009 01:48 PM
Darren wrote:Did you know...
You do if you read nuggets... 😉
11-23-2009
02:41 PM
- last edited on
11-23-2009
04:22 PM
by
Support
This thread inspired me.
I love the Place VI Contents option, but (and there's always a but) it is simply too cumbersome to go through the process of creating a VI with the template information and adding it to the palettes. Maybe not hard, but cumbersome and annoying. This ends up meaning that I rarely use this really nice feature, because I never have the time to stop what I'm doing and throw away 15 minutes, even if it saves me time down the road.
So... I decided a QuickDrop plugin would be a great way to solve this. I created a plugin for the letter G which does the following:
11-23-2009 03:03 PM
11-23-2009 03:23 PM
11-24-2009 07:10 AM
Hay Darren,
Nice Nugget
Ohiofudu
07-29-2010 10:51 AM
07-29-2010 12:28 PM
