Control the plots to be displayed during runtime.
Hi !
I am plotting several channel data in a chart in several plots.
I want to control the plots to be displayed during runtime.
That means I want to have a control for each plot, while the control is false that plot will not be displayed and while the control is true that plot will be displayed with others.
I have several sensors, I want to eliminate the sensors plot which does not contain significant data. But I do not know which one will not have relevant data.Because it is random so I need to choose it runtime.
Anybody can help me with this ??
Hasan
(2,618 Views)
Accepted by topic author hasanma
Hasan,
there is a property available called Plot>Visible. Using a property node you can toggle visibility regarding valid data.
Note that you have to select the correct plot first using the property Active Plot.
Norbert
Norbert
Expert: Geometry
(2,613 Views)
