Hello everybody,
I have a problem when choosing a color with a color control.
After choosing "more colors" and select an individual color from that color selection window, Labview doesn't go back to my application window. Instead I get back to the Windows Desktop and have to go back (by Tab or click the toolbar) to my Labview program. This seems to be independent of my application, I get this behaviour with development versions and executables, with windows with menu/scrollbar etc. enabled or disabled.
This only happens when I choose "more colors", when selecting colors from the normal/first window after clicking a color control Labview returns to my user interface. Any remarks?
Also "frustating": I set the beckground color of a text control with a property node. Normally I use short name format. In this case the property shows "NumText.BGColor". But this represents 2 different properties: "NumericText->
Colors->BG Color" and "NumericText->
TextColors->BG Color"! This is a little bit annoying, if I don't want to waste space on the block diagram. Couldn't LabView use two slightly different short names?
