10-17-2012 08:59 AM
I'm not looking to jump through many hoops to make it totally bulletproof. The company I work for is a small company, and we send an install disk with each of our products. I doubt we would be a good target for someone trying to sneak in a virus, but at the same time, I'm new to this and wanted to put in my due dilligence. I wanted to make sure I was doing it in a way that is an accepted practice in the industry, and that was recommended by NI. I think I have my answer to that. Thank you all for your input.
07-10-2015 12:03 PM
I'm trying to sign a build labview.app in OsX and get the error "unsealed contents present in the bundle root".
I believe this is due to locating "AppContents_x64.llb" outside of the "Contents" folder.
From the apple website,since Mavericks :
..." In addition, there may not be any content in the top level of a bundle. In other words, if a bundle has a Contents
or Versions
directory at its top level, there may be no other files or directories alongside them. The one exception is that alongside Versions
, there may be symlinks to files in Versions/Current
It sounds like everything including support frameworks belongs in the Contents folder of the .app bundle. Trying to set the support folder destination to MyProgram.app/Contents cause a permissions error that crashes the build. (maybe MyProgram.app doesn't exist when files are copied to the destination?)
One of our programmers modified the lvruntime framework so it will find a re-named AppContents.llb in the Contents folder, but this is not a great solution. Does anyone know of a workaround?
07-10-2015 04:29 PM
You posted into a 3 year old thread that has absolutely nothing to do with your question.
Please start a new message thread with your question.
