12-06-2005 02:48 AM
12-06-2005 03:10 AM
Should the excel need any style for it. example, characters' color, text size. text style, append picture etc.
if not. you can use "write characters to file.vi" this vi is easy controlled that write to the same worksheet ,as your option, run over or not the old data.
if you need some of excel's style. you can make the old data worksheet as a temp.xls. define the worksheet written position, thus, the data will not run over the old data.
12-06-2005 03:22 AM
12-06-2005 03:29 AM
you can do a checkings. before write data to the excel file, check where the empty field is. normally, I will define the first column as my checkings. and found it. get it's postion. and write the data to the temp file which includes old data.
if you choose " write characters to file.vi" the vi will add the data to the empty field automatically.
