CDAQ Module Interface
Please define CDAQ module interface connector ?
(1,938 Views)
Hi Akbar,
when you want to create your own module to plug into a cDAQ chassis you can get a Module Development Kit from NI with all needed informations…
(1,927 Views)
Accepted by topic author Akbar7110
The mdk only works with crio.
The interface is usually either Parallel for fast digital modules or spi for most modules.
It's a 15 pin high density d type connector, the same as vga.  It is possible to make a shrt breakout ca le to plug in the module without it being in the chassis and put a logic analyser on the IO lines. I did this for developing my own modules with the mdk.
Warning: this info is for fun only,  you won't get far, or anywhere with cdaq!
(1,891 Views)
